[Topic Unique] Asus P5K Deluxe - P5K et P5K-E
1) Descriptifs
2) Tests
3) Download
4) Photos
5)Complements d'informations
1) Descriptifs
CPU
LGA775 socket for Intel® Core™2 Quad / Core™2 Extreme / Core™2 Duo / Pentium® Extreme / Pentium® D / *Pentium® 4 Processors
Compatible with Intel® 05B/05A/06 processors
Support Intel® next generation 45nm multi-core CPU
*This motherboard supports FSB 1333/1066/800
Chipset
Intel® P35 / ICH9R with Intel® Fast Memory Access Technology
Front Side Bus
1333 / 1066 / 800 MHz
Memory
4 x DIMM, max. 8GB, DDR2 1066*/800 / 667 MHz, non-ECC, un-buffered memory
Dual channel memory architecture
* The chipset officially supports the memory frequency up to DDR2 800MHz. Tuned by ASUS Super Memspeed Technology, this motherboard natively supports up to DDR2 1066MHz
Please refer to www.asus.com or user manual for Memory QVL.
Expansion Slots
2 x PCI-E x16 (blue @ x16 mode, black @ x4 or x1 mode) supports CrossFire Technology
2 x PCI-E x1
3 x PCI
Storage
Southbridge
- 6 x SATA 3.0 Gb/s ports
- Supports RAID 0 and 1
JMicron® JMB363 PATA and SATA controller
- 1 x UltraDMA 133/100/66 for up to 2 PATA devices
- 2 x External SATA 3.0 Gb/s port (SATA On-the-Go)
- Supports SATA RAID 0,1 and JBOD
LAN
Dual Gigabit LAN controllers, featuring AI NET2
Marvell88E8056® PCI-E Gigabit LAN controllers
RealtekRTL8110SC® PCI Gigabit LAN controller
Wireless LAN
ASUS WiFi-AP Solo
54 Mbps IEEE 802.11g and backwards compatible with 11 Mbps IEEE 802.11b
- Software Access Point mode
- Station mode : Infrastruceure mode and Ad-Hoc mode
Audio
ADI® AD1988B 8-channel High Definition Audio CODEC
- Coaxial / Optical S/PDIF out ports at back I/O
- ASUS Noise Filter
IEEE 1394
Agere® FW322 1394a controller supports 2 x IEEE 1394a ports (one at midboard; one at back panel)
USB
10 x USB 2.0 ports (4 ports at mid-board, 6ports at back panel)
ASUS AI Lifestyle Features
ASUS Quiet Thermal Solution:
- ASUS AI Gear2
- ASUS AI Nap
- ASUS 8-Phase Power Design
- ASUS Fanless Design: Heat-pipe solution
- ASUS Fanless Design: Stack Cool 2
- ASUS Q-Fan 2
ASUS Crystal Sound:
- ASUS Noise Filter
ASUS EZ DIY:
- ASUS Q-Connector
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
- ASUS AI Slot Detector
ASUS WiFi@Home:
- ASUS WiFi-AP Solo
Other Features
ASUS MyLogo 3
Multi-language BIOS
Overclocking Features
Intelligent overclocking tools:
- AI NOS™ (Non-delay Overclocking System)
- ASUS AI Booster utility
Precision Tweaker:
- vCore: Adjustable CPU voltage at 0.0125V increment
- vDIMM: 16-step DRAM voltage control
- vChipset: 4-step Chipset voltage control
SFS (Stepless Frequency Selection)
- FSB tuning from 200MHz up to 800MHz at 1MHz increment
- Memory tuning from 667MHz up to 1333MHz for DDR2
- PCI Express frequency tuning from 100MHz up to150MHz at 1MHz increment
Overclocking Protection:
- ASUS C.P.R.(CPU Parameter Recall)
Back Panel I/O Ports
1 x PS/2 Keyboard
1 x S/PDIF Out (Coaxial + Optical)
2 x External SATA
1 x IEEE1394a
2 x RJ45 port
6 x USB 2.0/1.1
1 x WiFi-AP Solo antenna jack
8-channel Audio I/O
Internal I/O Connectors
2 x USB connectors support additional 4 USB ports
1 x Floppy disk drive connector
1 x IDE connector
1 x COM connector
6 x SATA connectors
1 x CPU Fan connector
4 x Chassis Fan connector
1 x Power Fan connector
1 x IEEE1394a connector
Front panel audio connector
1 x S/PDIF Out Header
Chassis Intrusion connector
CD audio in
24-pin ATX Power connector
2 x 4-pin ATX 12V Power connector
System Panel(Q-Connector)
BIOS
16 Mb Flash ROM, AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2, ASUS CrashFree BIOS 3
Manageability
WfM 2.0, DMI 2.0, WOL by PME, WOR by PME, PXE
Accessories
UltraDMA 133/100/66 cable
FDD cable
4 x Serial ATA cables
1 x 2-port Serial ATA power cable
I/O Shield
User's manual
ASUS WiFi-AP Solo manual
3 in 1 Q-connector
1 x 2-port USB2.0 / 1-port IEEE1394 module
ASUS WiFi-AP Solo omni-directional antenna
Support CD
Drivers
ASUS PC Probe II
ASUS Update
ASUS AI Suite
ASUS WiFi-AP Solo Wizard
Anti-virus software (OEM version)
Image-Editing Suite
Form Factor
ATX Form Factor, 12"x 9.6" (30.5cm x 24.4cm)
2) Tests
http://www.clubic.com/article-73884-6-chipset-intel-p35-core-2-duo-ddr3-intel-bearlake.html
http://www.jmax-hardware.com/index.php?option=com_content&task=view&id=105&Itemid=1
http://www.legionhardware.com/document.php?id=644
http://www.hexus.net/content/item.php?item=8764
http://www.cpu3d.com/motherboards/asus_p5k_deluxe_motherboard.html
http://www.matbe.com/articles/lire/384/core-2-duo-e6850-p35-et-ddr3/page6.php
http://www.hardware.fr/articles/674-8/intel-p35-express-fsb1333-ddr3.html
3) Download
Bios :
Version
202:
http://dlsvr01.asus.com/pub/ASUS/mb/socket775/P5K%20Deluxe/0202.zip
Version
311:
http://dlsvr01.asus.com/pub/ASUS/mb/socket775/P5K%20Deluxe/0311.zip
Audio :
Vista 64bit
http://dlsvr01.asus.com/pub/ASUS/misc/audio/SoundmaxAD1988_Audio_v610X6180_Vista.zip
Vista 32bit
Win XP64
http://dlsvr01.asus.com/pub/ASUS/misc/audio/SoundmaxAD1988_Audio_v510026110_64bit.zip
WinXP
http://dlsvr01.asus.com/pub/ASUS/misc/audio/SoundmaxAD1988_Audio_v510016110_32bit.zip
LAN :
Realtek RTL8110SC Lan Driver
Vista 64bit
http://dlsvr01.asus.com/pub/ASUS/lan/RTL8110SC/RTL8110SC_Lan_V566312122006_V61901152007.zip
Vista 32Bit
WinXP64
WinXP
Marvell Yukon Gigabit Ethernet Driver
Vista 64bit
http://dlsvr01.asus.com/pub/ASUS/lan/marvell/Marvel8056_Lan.zip
Vista 32Bit
[url][/url]
WinXP64
[url][/url]
WinXP
RAID :
Vista 64bit
http://dlsvr01.asus.com/pub/ASUS/misc/sata/JMicronJMB363_RAID_V117150.zip
Vista 32Bit
WinXP64
WinXP
Utilitaires :
Asus Probe 1.04.19
XP - Vista
http://dlsvr01.asus.com/pub/ASUS/misc/utils/ProbeII_V10419.zip
Others :
Linux Drivers
http://dlsvr01.asus.com/pub/ASUS/mb/socket775/P5K%20Deluxe/LinuxDrivers.zip
4) Photos
Bundle
View de coté
Composant
5) Complement d'information
certains membres rencontre des problemes de sifflement => retour SAV
--Message édité par le 20-06-07 à 22:12:36--
